Einleitung
This guide will walk you through the steps on how to replace your Levono Legion y520 fan. In cases when your fan maybe overheating or not working you will need this guide. NOTE: There are a lot of wires. Be sure to keep track of where each one goes.
Was du brauchst
Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
Flip the laptop on its side and wedge a spudger between the base panel and chassis, then pry around the perimeter until the base panel releases.
Lift the bottom panel off of the chassis.
Unplug the battery then, you will need to remove the four 4 mm screws around the fan using a Phillips #00 screwdriver.
9 weitere Personen haben diese Anleitung absolviert.
