Zum Hauptinhalt wechseln
Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement
Was du brauchst
  1. Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement, Keyboard Keycap: Schritt 1, Bild 1 von 3 Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement, Keyboard Keycap: Schritt 1, Bild 2 von 3 Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement, Keyboard Keycap: Schritt 1, Bild 3 von 3
    • Carefully remove the broken key(s). Use the flat end of the spudger to gently pop the key off.
    • When removing the key(s) be very cautious not to remove the white plastic pieces underneath with it.
    • When reinstalling key, no spudger is needed. Just pop it into place with fingers.
  2. Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement: Schritt 2, Bild 1 von 2 Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement: Schritt 2, Bild 2 von 2
    • Using the flat end of the spudger, very carefully lift up the corners of the white plastic piece. Do not disconnect the two.
    • With the help of tweezers (needle nose works best), pull the connected plastic pieces out.
    • If the two plastic pieces come apart refer to the last picture, showing the orientation in which they should be connected.
    • For reinstallation of the plastic piece use tweezers to put it back in place and pop the bottom half in before the top.
Abschluss
Kaylea
185 Reputation
1 Anleitung geschrieben
3 Kommentare
This is only for the key caps, what about the keyboard itself?
Rick Montoya - Antwort
I agree the video is mislabeled. You are not replacing the board just keys.
Pat Schutte - Antwort
Please create a tutorial for keys with stabilizer like space bar and enter keys.
Affix - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 39
Letzte 30 Tage: 154
Insgesamt: 10,062
