Zum Hauptinhalt wechseln
Lenovo Legion Y530-15ICH Fan Replacement
Was du brauchst
  1. Lenovo Legion Y530-15ICH Fan Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7 mm screws
    • Six 4 mm screws
  2. Lenovo Legion Y530-15ICH Fan Replacement: Schritt 2, Bild 1 von 2 Lenovo Legion Y530-15ICH Fan Replacement: Schritt 2, Bild 2 von 2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH Fan Replacement, Fan: Schritt 3, Bild 1 von 2 Lenovo Legion Y530-15ICH Fan Replacement, Fan: Schritt 3, Bild 2 von 2
    • Use a JIS #1 screwdriver to loosen the five spring screws located at the middle of the fan piece.
    • Remove the plastic covering after the screws have been loosened.
    • Spring screws will stay attached to the cover.
  4. Lenovo Legion Y530-15ICH Fan Replacement: Schritt 4, Bild 1 von 1
    • Use a JIS #1 screwdriver to remove four 4mm screws securing the fans to the device.
  5. Lenovo Legion Y530-15ICH Fan Replacement: Schritt 5, Bild 1 von 1
    • Unplug the wires connecting the two fans to the motherboard.
    • When doing this, tug carefully from side to side.
  6. Lenovo Legion Y530-15ICH Fan Replacement: Schritt 6, Bild 1 von 2 Lenovo Legion Y530-15ICH Fan Replacement: Schritt 6, Bild 2 von 2
    • Lift the fans out of their positions and remove them from the device.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S7-G1, Regan Winter 2020 Mitglied von Cal Poly, Team S7-G1, Regan Winter 2020
CPSU-REGAN-W20S7G1
4 Mitglieder
12 Anleitungen geschrieben
4 Kommentare
Thank you! Very clear and well photographed :)
Daniel Perez - Antwort
Any recommended stores for the replacement fans?
Ivan Ramljak - Antwort
Worked like a charm, thank you!!
Skyler Boyle - Antwort
where can i get a good replacement please
peters pelumi - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 53
Letzte 30 Tage: 232
Insgesamt: 12,113
