Zum Hauptinhalt wechseln
Lenovo Legion Y530-15ICH USB Port Replacement
Was du brauchst
  1. Lenovo Legion Y530-15ICH USB Port Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7 mm screws
    • Six 4 mm screws
  2. Lenovo Legion Y530-15ICH USB Port Replacement: Schritt 2, Bild 1 von 2 Lenovo Legion Y530-15ICH USB Port Replacement: Schritt 2, Bild 2 von 2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH USB Port Replacement, USB Port: Schritt 3, Bild 1 von 2 Lenovo Legion Y530-15ICH USB Port Replacement, USB Port: Schritt 3, Bild 2 von 2
    • Remove the ribbon cable connecting the USB port to the motherboard, located adjacent to the fan unit.
    • Using a JIS #1 screwdriver, remove the two screws securing the USB port to the module.
  4. Lenovo Legion Y530-15ICH USB Port Replacement: Schritt 4, Bild 1 von 1
    • Gently disconnect the single ribbon cable with your fingers.
    • Remove the USB port from the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 961
