Einleitung
This guide replaces the USB port for the Lenovo Legion Y530-15ICH, overtime with use it make break/get water damaged. This is especially important if the user needs to connect a smartphone.
Was du brauchst
Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
Five 7 mm screws
Six 4 mm screws
Remove the ribbon cable connecting the USB port to the motherboard, located adjacent to the fan unit.
Using a JIS #1 screwdriver, remove the two screws securing the USB port to the module.
Gently disconnect the single ribbon cable with your fingers.
Remove the USB port from the device.
