Zum Hauptinhalt wechseln
Lenovo Legion Y530-15ICH Wireless LAN Card Replacement
Was du brauchst
  1. Lenovo Legion Y530-15ICH Wireless LAN Card Replacement, Wireless LAN Card: Schritt 1, Bild 1 von 1
    • Make sure your computer is turned off.
    • Remove the five 7 mm screws using a Phillips #0 screwdriver.
    • Remove the six 4 mm screws using a Phillips #0 screwdriver.
  2. Lenovo Legion Y530-15ICH Wireless LAN Card Replacement: Schritt 2, Bild 1 von 1
    • Slowly and carefully pry off the backside of the computer using an opening pick.
    • You can start from the corner or sides of computer. Slowly work around the computer until it completely detaches.
  3. Lenovo Legion Y530-15ICH Wireless LAN Card Replacement: Schritt 3, Bild 1 von 1
    • Detach the two antenna wires attached to the wireless LAN card.
  4. Lenovo Legion Y530-15ICH Wireless LAN Card Replacement: Schritt 4, Bild 1 von 1
    • Remove the single 4 mm screw using a Phillips #0 screwdriver.
    • Remove the wireless LAN card.
  5. Lenovo Legion Y530-15ICH Wireless LAN Card Replacement: Schritt 5, Bild 1 von 1
    • Insert the new wireless LAN card.
    • Re-insert the 4 mm screw using Phillips #0 screwdriver.
    • It's normal for the wireless LAN card to pop up slightly. It will fit into place when you screw it back in.
  6. Lenovo Legion Y530-15ICH Wireless LAN Card Replacement: Schritt 6, Bild 1 von 1
    • Re-attach the black antenna cable to the top pin on the wireless LAN card.
    • Re-attach the white antenna cable to the bottom pin on the wireless LAN card.
  7. Lenovo Legion Y530-15ICH Wireless LAN Card Replacement: Schritt 7, Bild 1 von 1
    • Snap the back cover onto the laptop.
    • Using a Phillips #0 screwdriver, re-insert the five 7mm screws.
    • Using a Phillips #0 screwdriver, re-insert the six 4mm screws.
Abschluss
After replacing the faulty wireless LAN card, you should be able to connect to a wireless network connection. The connection should be stable and not randomly disconnecting. If this doesn’t fix your problem, then you may have to check the router or wireless connection point.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
York University, Team S2-G18, Melo-Thaiss Fall 2020 Mitglied von York University, Team S2-G18, Melo-Thaiss Fall 2020
YORK-MELO-THAISS-F20S2G18
1 Mitglied
1 Anleitung geschrieben
Ein Kommentar
Great guide! I would like to note that when removing the bottom panel some of the seam, especially around the side vents, can be a little hard to find as the seam follows the vent from the bottom to the top. I started prying at the front and then moved to the back, and then to the vent areas on the sides last. That helped make getting the pick in around the vents easier.
ingow - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 26
Insgesamt: 1,944
