Zum Hauptinhalt wechseln
Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement
Was du brauchst
  1. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement, W-Fi Card: Schritt 1, Bild 1 von 3 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement, W-Fi Card: Schritt 1, Bild 2 von 3 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement, W-Fi Card: Schritt 1, Bild 3 von 3
    • Using the Phillips #00 screws, remove 13 screws from the backside of the laptop.
    • Five 2x1/2 screws.
    • Eight 1x1/2 screws.
  2. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: Schritt 2, Bild 1 von 1
    • Pry open the back cover open with a plastic opening tool.
  3. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: Schritt 3, Bild 1 von 2 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: Schritt 3, Bild 2 von 2
    • Carefully remove the taped on paper under the fans.
  4. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: Schritt 4, Bild 1 von 3 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: Schritt 4, Bild 2 von 3 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: Schritt 4, Bild 3 von 3
    • Remove the four screws that are holding the battery down using a Phillips #00 screwdriver.
    • Disconnect and remove the battery from the device.
  5. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: Schritt 5, Bild 1 von 3 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: Schritt 5, Bild 2 von 3 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: Schritt 5, Bild 3 von 3
    • Using a plastic opening tool, carefully disconnect the two cables connected to the Wi-Fi card.
  6. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: Schritt 6, Bild 1 von 3 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: Schritt 6, Bild 2 von 3 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: Schritt 6, Bild 3 von 3
    • Using the Phillips #00 screwdriver, remove the screw holding the Wi-Fi card to the device.
    • Remove the Wi-Fi Card from the device.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
CSU Los Angeles, Team S12-G18, Harris Fall 2020 Mitglied von CSU Los Angeles, Team S12-G18, Harris Fall 2020
CSULA-HARRIS-F20S12G18
1 Mitglied
1 Anleitung geschrieben
3 Kommentare
Thanks for the guide Lawrence, can I ask what card you replaced the stock one with?
mkrnblack - Antwort
I reccomend using the Wireless AC 8265 with bluetooth. There is the one I bought:
Intel Dual Band Wireless-Ac 8265... https://www.amazon.com/dp/B01MZA1AB2?ref...
Hope it goes well for you, it should fix all the ping spikes and unstable internet from the stock lenovo wifi chip.
Lawrence Lam -
Thanks for the recommendation I originally went with the 9560.NGWG.NV but It was not an improvement, in fact it might be worse. So I will try the 8265.
mkrnblack - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 30
Insgesamt: 1,370
