Zum Hauptinhalt wechseln
Lenovo Miix 2 Speakers Replacement
Was du brauchst
  1. Lenovo Miix 2 Speakers Replacement, Battery: Schritt 1, Bild 1 von 2 Lenovo Miix 2 Speakers Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps.
    • You should have to apply a good amount of force, but pry carefully in order to avoid damaging the clasps or the internals.
  2. Lenovo Miix 2 Speakers Replacement: Schritt 2, Bild 1 von 2 Lenovo Miix 2 Speakers Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver.
  3. Lenovo Miix 2 Speakers Replacement: Schritt 3, Bild 1 von 2 Lenovo Miix 2 Speakers Replacement: Schritt 3, Bild 2 von 2
    • Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard.
  4. Lenovo Miix 2 Speakers Replacement: Schritt 4, Bild 1 von 2 Lenovo Miix 2 Speakers Replacement: Schritt 4, Bild 2 von 2
    • Remove the battery by prying up with your fingers or a plastic opening tool.
  5. Lenovo Miix 2 Speakers Replacement, Speakers: Schritt 5, Bild 1 von 2 Lenovo Miix 2 Speakers Replacement, Speakers: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Remove the red and black connector cable linking the speakers to the motherboard with tweezers by pulling the connector to the left with a light degree of force.
    • To properly remove the speakers from the casing, push gently left until it shifts, then pull directly up.
Abschluss
Diana Chiu
654 Reputation
4 Anleitungen geschrieben
Kid fixers Mitglied von Kid fixers
Community
187 Mitglieder
256 Anleitungen geschrieben
0 Guide Comments
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 983
