Zum Hauptinhalt wechseln
Lenovo Miix 2 Vibrating Cable Replacement
Was du brauchst
  1. Lenovo Miix 2 Vibrating Cable Replacement, Battery: Schritt 1, Bild 1 von 2 Lenovo Miix 2 Vibrating Cable Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps.
    • You should have to apply a good amount of force, but pry carefully in order to avoid damaging the clasps or the internals.
  2. Lenovo Miix 2 Vibrating Cable Replacement: Schritt 2, Bild 1 von 2 Lenovo Miix 2 Vibrating Cable Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver.
  3. Lenovo Miix 2 Vibrating Cable Replacement: Schritt 3, Bild 1 von 2 Lenovo Miix 2 Vibrating Cable Replacement: Schritt 3, Bild 2 von 2
    • Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard.
  4. Lenovo Miix 2 Vibrating Cable Replacement: Schritt 4, Bild 1 von 2 Lenovo Miix 2 Vibrating Cable Replacement: Schritt 4, Bild 2 von 2
    • Remove the battery by prying up with your fingers or a plastic opening tool.
  5. Lenovo Miix 2 Vibrating Cable Replacement, Vibrating Cable: Schritt 5, Bild 1 von 3 Lenovo Miix 2 Vibrating Cable Replacement, Vibrating Cable: Schritt 5, Bild 2 von 3 Lenovo Miix 2 Vibrating Cable Replacement, Vibrating Cable: Schritt 5, Bild 3 von 3
    • Remove the vibrator cable which is connected with a white connector head to the motherboard, by gently lifting on the connector head with tweezers.
    • Remove the vibrator head by following the black and wire cable from the motherboard to where the head is located.
Abschluss
Max Rozema
157 Reputation
2 Anleitungen geschrieben
IUPUI, Team S3-G1, Harley Spring 2019 Mitglied von IUPUI, Team S3-G1, Harley Spring 2019
IUPUI-HARLEY-S19S3G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 195
