Einleitung
here is a guide to help you locate the I/O Board for inspection, repairs, or replacement. The tools you will need are the Phillips #0 Screwdriver, Metal Spudger, and the Spudger.
Was du brauchst
Carefully, disconnect the keyboard cable from the motherboard carefully by pulling on the blue tab of the cable.
You will now be able to replace the keyboard.
Remove the two rubber feet of the back of the Chromebook using a metal spudger.
Remove six bottom 3.5 mm Phillips #0 screws and two top 5 mm Phillips #1 screws.
Disconnect the battery cable from the motherboard.
Disconnect the touch-pad cable from the motherboard.
Use the metal spudger along the seam between the keyboard and the bottom of the Chromebook to lift up and remove the palm rest assembly.
Disconnect the USB cable from the motherboard by pulling the blue tab out of the cable.
Remove all five 3.0 mm Phillips #00 screws which connect the battery and motherboard.
Once the battery has been removed, you need make sure that you have removed the I/O cable that is attached to the I/O Board.
Using the flat end of the Spudger tool, carefully lift the I/O Board.
