Einleitung
This guide shows how to replace the WLAN & Bluetooth for the Lenovo N20p Chromebook. The guide shows how to remove the back panel, and remove the screws holding the WLAN & Bluetooth in place.
Was du brauchst
Carefully, disconnect the keyboard cable from the motherboard carefully by pulling on the blue tab of the cable.
You will now be able to replace the keyboard.
Remove the two rubber feet of the back of the Chromebook using a metal spudger.
Remove six bottom 3.5 mm Phillips #0 screws and two top 5 mm Phillips #1 screws.
Disconnect the battery cable from the motherboard.
Disconnect the touch-pad cable from the motherboard.
Use the metal spudger along the seam between the keyboard and the bottom of the Chromebook to lift up and remove the palm rest assembly.
Disconnect the USB cable from the motherboard by pulling the blue tab out of the cable.
Remove all five 3.0 mm Phillips #00 screws which connect the battery and motherboard.
Disconnect the white and black cables from the WLAN & Bluetooth combo.
Remove the 2 mm Phillips #1 screw.
Lift and pull the WLAN & Bluetooth in the direction shown.
