Einleitung
Once the keyboard and touch pad have been removed, the battery can be easily replaced by removing three screws and a connection cable.
Was du brauchst
Use a screwdriver to remove the six 5.0mm Phillips screws from the bottom housing of the Chromebook.
Use a plastic opening tool to pry off the four rubber pegs from the bottom housing.
Use a screwdriver to remove the four 5.0mm Phillips screws located under the rubber soles.
Flip the laptop over and open the screen.
Gently pry the keyboard and trackpad panel away from the bottom housing using a plastic opening tool.
Disconnect the keyboard ribbon cable by lifting the ZIF connector lock with a plastic opening tool or fingernail and gently pulling the ribbon cable straight out of its socket.
Disconnect the trackpad ribbon cable by lifting the ZIF connector lock with a small prying tool or fingernail and gently pulling the ribbon cable straight out of its socket.
Disconnect the white charging cable connectors by pulling straight down on the connector.
Use a Phillips screwdriver to remove the three 3mm screws located along the edge of the battery.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
