Einleitung
Through this guide you will be able to remove and replace individual keys on your keyboard. This process may be necessary if the key is not responsive to the touch.
Was du brauchst
Loosen the key by prying on the edge of the key with the plastic opening tool.
Remove the key from the keyboard by prying the key off with the opener or with your finger.
13 weitere Nutzer:innen haben diese Anleitung absolviert.
6 Kommentare
Where can I order individual keys?
He tried to turn it on but it did not work
I took it off and now it broken he he
Yeah so I tried this on my computer to clean my keys and now my alt key won’t go back in. I also got my g key partially stuck in so only the right side of it works. Is there anything I am supposed to do?
