Zum Hauptinhalt wechseln
Lenovo N22 Chromebook Individual Key Replacement
Was du brauchst
  1. Lenovo N22 Chromebook Individual Key Replacement, Individual Key: Schritt 1, Bild 1 von 1
    • Power down the chromebook before starting this process.
    • Loosen the key by prying on the edge of the key with the plastic opening tool.
  2. Lenovo N22 Chromebook Individual Key Replacement: Schritt 2, Bild 1 von 2 Lenovo N22 Chromebook Individual Key Replacement: Schritt 2, Bild 2 von 2
    • Remove the key from the keyboard by prying the key off with the opener or with your finger.
    • The key is connected to the keyboard with two connecting plastic squares. One is connected to the keyboard by tabs and one is connected to the keyboard by snaps.
    • When reassembling make sure that the two plastic square connectors are in the same place as when you removed the key.
Abschluss
13 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S21-G1, Livingston Spring 2017 Mitglied von Cal Poly, Team S21-G1, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G1
4 Mitglieder
14 Anleitungen geschrieben
6 Kommentare
very vague info. If a Key does not work and I take it out, why should it work once back in?? what do I need to change or look for? seems like very good instructions to take the keys out of a notebook
edperalt - Antwort
Where can I order individual keys?
Mallory Montreuil - Antwort
He tried to turn it on but it did not work
Clayton Sensing - Antwort
I took it off and now it broken he he
BRENNEN FIRKUS - Antwort
Yeah so I tried this on my computer to clean my keys and now my alt key won’t go back in. I also got my g key partially stuck in so only the right side of it works. Is there anything I am supposed to do?
Anushka Halepet - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 16
Letzte 30 Tage: 79
Insgesamt: 14,371
