Einleitung
This guide will cover the steps needed to remove the speakers. The speakers may need to be removed if the user is experiencing distorted or no audio.
Was du brauchst
Flip the Chromebook so that the bottom is facing up.
Use a Phillips #1 screwdriver to remove the six 6.6 mm screws on the bottom.
Use a spudger to remove each of the 4 rubber feet.
Use a Phillips #1 screwdriver to remove the four additional screws under the rubber feet.
Flip the Chromebook back over and open the screen.
Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook.
Run the plastic opening tool along the seam between the keyboard and the bottom of the Chromebook until the keyboard moves freely. Several tabs will pop out.
Once the keyboard is released, grab the two top corners closest to the screen and slowly lift the keyboard up.
Disconnect the cables by lifting up the retaining flaps on the black ZIF connectors.
Slowly pull the cables up and out of the connectors.
Lift the keyboard up and off the back panel, exposing the motherboard and battery.
Separate the battery cable from the motherboard by wedging the edge of a plastic opening tool between the black cable connector and the silver socket on the motherboard.
Pull the battery cable straight towards you, away from the silver socket.
Use a Philips #1 screwdriver to remove the three 4.3 mm screws securing the battery.
Use the edge of the opening tool to separate the speaker cable connector from the black socket on the motherboard.
Pull the cables towards you and away from the socket.
Use the pointed end of the spudger to pop the speaker up and off of the two posts.
Slide the wire that connects the two separate speakers out from under the guide tabs.
Use the flat end of the spudger to pop the speaker up and off of the two posts.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
