Einleitung
This guide will show you how to remove the wireless card from your chromebook. You can replace the wireless card once you have removed it.
Was du brauchst
Flip the Chromebook so that the bottom is facing up.
Use a Phillips #1 screwdriver to remove the six 6.6 mm screws on the bottom.
Use a spudger to remove each of the 4 rubber feet.
Use a Phillips #1 screwdriver to remove the four additional screws under the rubber feet.
Flip the Chromebook back over and open the screen.
Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook.
Run the plastic opening tool along the seam between the keyboard and the bottom of the Chromebook until the keyboard moves freely. Several tabs will pop out.
Once the keyboard is released, grab the two top corners closest to the screen and slowly lift the keyboard up.
Disconnect the cables by lifting up the retaining flaps on the black ZIF connectors.
Slowly pull the cables up and out of the connectors.
Lift the keyboard up and off the back panel, exposing the motherboard and battery.
Use a Philips #1 screwdriver to remove the 3.6 mm screw from the back panel.
Gently slide the wireless card to the right to remove it from the standard socket on the motherboard.
Grab the black and white wires as close to the antenna cable connectors as possible.
Gently pull the black and white wires away from the antenna cable connectors on the wireless card.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Very well explained and photographed. My first attempt at a laptop repair and this guide made it possible.
Thanks!
