Zum Hauptinhalt wechseln
Lenovo N23 Chromebook LCD Screen Replacement
Was du brauchst
  1. Lenovo N23 Chromebook LCD Screen Replacement, Battery: Schritt 1, Bild 1 von 2 Lenovo N23 Chromebook LCD Screen Replacement, Battery: Schritt 1, Bild 2 von 2
    • Before starting, make sure that the laptop is powered off and completely unplugged from the charger.
    • Remove the eight 6.0 mm screws holding the back into place using a Phillips #0 screwdriver.
  2. Lenovo N23 Chromebook LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Flip the device over.
    • Slide a plastic opening tool between the back cover and keyboard.
    • Carefully pry upwards until you hear a click.
    • Following the seam, slide the opening tool all the way around the front cover, prying upwards occasionally until the keyboard and trackpad are loose from the back cover.
    • Lift the keyboard panel up to reveal the internals.
    • Don't lift the keyboard panel too violently, as there is still a cable attachment to the motherboard.
  3. Lenovo N23 Chromebook LCD Screen Replacement: Schritt 3, Bild 1 von 3 Lenovo N23 Chromebook LCD Screen Replacement: Schritt 3, Bild 2 von 3 Lenovo N23 Chromebook LCD Screen Replacement: Schritt 3, Bild 3 von 3
    • You can now access the internals of the computer.
    • Disconnect the two ribbon cables that connect from the motherboard to the front cover.
    • Using the iFixit opening tool, flip up the black tab holding keyboard ribbon cable and then pull the cable out.
    • Using the opening tool, flip the white tab holding the mouse ribbon cable and then pull the cable out.
  4. Lenovo N23 Chromebook LCD Screen Replacement: Schritt 4, Bild 1 von 2 Lenovo N23 Chromebook LCD Screen Replacement: Schritt 4, Bild 2 von 2
    • Lift the keyboard panel from the case and fully remove it from the device.
  5. Lenovo N23 Chromebook LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Using the Phillips #0 screwdriver, remove the two 3 mm screws holding the battery in place.
  6. Lenovo N23 Chromebook LCD Screen Replacement: Schritt 6, Bild 1 von 3 Lenovo N23 Chromebook LCD Screen Replacement: Schritt 6, Bild 2 von 3 Lenovo N23 Chromebook LCD Screen Replacement: Schritt 6, Bild 3 von 3
    • Disconnect the battery cable using a plastic opening tool by pulling on the black plastic lip.
    • Lift the battery out of the laptop.
  7. Lenovo N23 Chromebook LCD Screen Replacement, LCD Screen: Schritt 7, Bild 1 von 3 Lenovo N23 Chromebook LCD Screen Replacement, LCD Screen: Schritt 7, Bild 2 von 3 Lenovo N23 Chromebook LCD Screen Replacement, LCD Screen: Schritt 7, Bild 3 von 3
    • Remove the two rubber stoppers and two paper covers on the screen bezel using a metal spudger.
    • Remove the four 3.0 mm Phillips #0 screws holding the screen and bezel in place.
  8. Lenovo N23 Chromebook LCD Screen Replacement: Schritt 8, Bild 1 von 2 Lenovo N23 Chromebook LCD Screen Replacement: Schritt 8, Bild 2 von 2
    • Use a plastic opening tool to gently pry upwards on the bezel until a small click can be heard.
    • Do this around the left, top, and right bezels. The bottom bezel is glued in place but can easily be separated by prying as well.
    • Using a plastic opening tool, press firmly at the split of both hinges until a click sound is heard and the two sides of the hinge cover are separated.
  9. Lenovo N23 Chromebook LCD Screen Replacement: Schritt 9, Bild 1 von 3 Lenovo N23 Chromebook LCD Screen Replacement: Schritt 9, Bild 2 von 3 Lenovo N23 Chromebook LCD Screen Replacement: Schritt 9, Bild 3 von 3
    • Using a plastic opening tool, disconnect the video cable connecting the screen to the motherboard.
    • Pull off the bezel to view the screws holding the screen in place.
  10. Lenovo N23 Chromebook LCD Screen Replacement: Schritt 10, Bild 1 von 3 Lenovo N23 Chromebook LCD Screen Replacement: Schritt 10, Bild 2 von 3 Lenovo N23 Chromebook LCD Screen Replacement: Schritt 10, Bild 3 von 3
    • Remove four 3.0 mm screws holding the screen in place using a Phillips #0 screwdriver.
    • Using an iFixit opening tool, carefully lift the screen from the screen mount bracket and place it facedown where the keyboard would usually rest.
  11. Lenovo N23 Chromebook LCD Screen Replacement: Schritt 11, Bild 1 von 3 Lenovo N23 Chromebook LCD Screen Replacement: Schritt 11, Bild 2 von 3 Lenovo N23 Chromebook LCD Screen Replacement: Schritt 11, Bild 3 von 3
    • Peel back the tape holding the display cable connector in place.
    • Carefully pull backwards on the cable to disconnect it from the screen and lift screen out of the laptop.
Abschluss
Jarod Ostir
465 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 32
Insgesamt: 821
