Einleitung
How to replace the Lenovo N23 Chromebook motherboard
Was du brauchst
Remove the eight 6.0 mm screws holding the back into place using a Phillips #0 screwdriver.
Flip the device over.
Slide a plastic opening tool between the back cover and keyboard.
Carefully pry upwards until you hear a click.
Following the seam, slide the opening tool all the way around the front cover, prying upwards occasionally until the keyboard and trackpad are loose from the back cover.
Lift the keyboard panel up to reveal the internals.
Disconnect the two ribbon cables that connect from the motherboard to the front cover.
Using the iFixit opening tool, flip up the black tab holding keyboard ribbon cable and then pull the cable out.
Using the opening tool, flip the white tab holding the mouse ribbon cable and then pull the cable out.
Using the Phillips #0 screwdriver, remove the two 3 mm screws holding the battery in place.
Disconnect the battery cable using a plastic opening tool by pulling on the black plastic lip.
Lift the battery out of the laptop.
Use a plastic opening tool to disconnect the two coaxial cables from the Wi-Fi card.
Tuck the two wires out of the way.
Remove the single 3.0 mm Phillips #1 screw holding the Wi-Fi card using a Phillips #1 screwdriver.
Using your hands, carefully pull the Wi-Fi card sideways out of the port on the motherboard.
Remove the USB ribbon cable by lifting up on the white tab using a plastic opening tool and then pulling the cable out.
Disconnect the two black connectors on the bottom left side of the motherboard by pulling back on the lip with a plastic opening tool.
Disconnect the video cable by lifting upwards on the black tab using a plastic opening tool and pulling the cable out.
Remove the five 3.0 mm screws that hold the motherboard in place with a Phillips #0 screwdriver.
Lift the motherboard carefully out of the laptop, being sure to not let it get caught on any cables.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
