Zum Hauptinhalt wechseln
Lenovo N23 Yoga Keyboard Replacement
Was du brauchst
  1. Lenovo N23 Yoga Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 3 Lenovo N23 Yoga Keyboard Replacement, Keyboard: Schritt 1, Bild 2 von 3 Lenovo N23 Yoga Keyboard Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Flip the computer over.
    • Remove the 9 screws surrounding the edges of the computer.
    • Remove the single screw near the center of the computer.
  2. Lenovo N23 Yoga Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Use a smaller plastic panel popping tool to begin (if you have one). You may increase to a larger size as you go (if you have one)
    • Slowly work your way around the edges of the computer.
    • Closer to the screen the clips will be sturdier, use a little more force but still be cautious.
  3. Lenovo N23 Yoga Keyboard Replacement: Schritt 3, Bild 1 von 1
    • On the main board, lift up on the black tabs of the connectors that are connected to the ribbons.
    • Remove the ribbon connectors gently from the main board.
  4. Lenovo N23 Yoga Keyboard Replacement: Schritt 4, Bild 1 von 1
    • The keyboard should be free and disconnected from the rest of the computer.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Drew Canada
1.370 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 1,542
