Was du brauchst
Locate the large black panel with the round vent. It will have two Phillips head screws. Loosen them with a screwdriver until they start making a clicking noise. The screws stay captive in the cover.
To remove the panel, pull up from this tab. Lift the panel with the tab located between the screws using a flathead screwdriver or your fingernail. You will encounter resistance from the plastic snap tabs that are on the cover. Gently pry around the corners on either side of the front until the panel pops up. Lift off the panel carefully.
To remove the fan, remove the three screws that hold it into the system. Disconnect the fan before removing it.
Clean out the fins in the heatsink. To do this, use a can of compressed air.
The second image shows the dust from the heat sink.
Reassemble the laptop by following this guide in reverse.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
