Zum Hauptinhalt wechseln
Lenovo S20-30 Keyboard Replacement
Was du brauchst
  1. Lenovo S20-30 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the Lenovo S20-30 over so that the bottom panel is facing upward.
  2. Lenovo S20-30 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Slide the manual battery latch to the unlock position, so that the red is showing.
  3. Lenovo S20-30 Keyboard Replacement: Schritt 3, Bild 1 von 2 Lenovo S20-30 Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Slide and hold the spring-loaded battery latch on the other side (right) while sliding the battery out of the computer.
    • Grab new Lenovo S20-30 battery for replacement.
  4. Lenovo S20-30 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 3 Lenovo S20-30 Keyboard Replacement, Keyboard: Schritt 4, Bild 2 von 3 Lenovo S20-30 Keyboard Replacement, Keyboard: Schritt 4, Bild 3 von 3
    • Remove the two front rubber feet using a long metal spudger.
    • Use your Phillips #0 screwdriver to remove the two M2.5 x 5mm flat-head screws located underneath the pads.
  5. Lenovo S20-30 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Use the Phillips #0 screwdriver to remove the nine M2 x 4mm flat head screws located on the outer edges on the back of the laptop.
    • Make sure to keep these screws separated from future screws that will be disassembled throughout this process.
  6. Lenovo S20-30 Keyboard Replacement: Schritt 6, Bild 1 von 2 Lenovo S20-30 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Use the long metal spudger to pry open the bottom half of the laptop.
    • Gently lift the cover off to reveal the motherboard.
  7. Lenovo S20-30 Keyboard Replacement: Schritt 7, Bild 1 von 2 Lenovo S20-30 Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Remove the four M2 x 3mm flat-head screw using a Phillips #000 screwdriver.
  8. Lenovo S20-30 Keyboard Replacement: Schritt 8, Bild 1 von 2 Lenovo S20-30 Keyboard Replacement: Schritt 8, Bild 2 von 2
    • Flip over laptop and open the lid to have access to the keyboard.
    • Use a plastic opening tool to pry apart the keyboard.
  9. Lenovo S20-30 Keyboard Replacement: Schritt 9, Bild 1 von 3 Lenovo S20-30 Keyboard Replacement: Schritt 9, Bild 2 von 3 Lenovo S20-30 Keyboard Replacement: Schritt 9, Bild 3 von 3
    • A connector is attached to the keyboard.
    • Remove it by gently pulling it outward.
  10. Lenovo S20-30 Keyboard Replacement: Schritt 10, Bild 1 von 1
    • Grab replacement keyboard to insert back into place.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
McKendree University, Team S1-G4, Quinn Fall 2018 Mitglied von McKendree University, Team S1-G4, Quinn Fall 2018
MCKU-QUINN-F18S1G4
2 Mitglieder
3 Anleitungen geschrieben
Ein Kommentar
where can i find a replacement keyboard/ or what model # do i need?
ed paz - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 20
Insgesamt: 1,238
