Einleitung
Bring life back to your Lenovo Tab 2 A10-70 with a new battery.
Was du brauchst
Use a plastic opening tool to pry open the back cover of the tablet.
The second picture shows the tablet with the back removed.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Remove the tape that secures the ribbon cable.
Use precision tweezers if the tape cannot be removed by hand.
Carefully remove the ribbon cable from the power button connector.
To remove the cable, push the clamp on the connector up and pull gently.
Remove the following screws securing the metal frame holding the battery.
Five 2 mm Philips screws.
Remove the grey tape.
Unscrew the hidden 2mm screw using the Phillips #000 drill bit.
Remove the second piece of tape from the other ribbon cable connected to the battery.
Remove the screws securing the battery connector cover.
Two 2mm Phillips screws.
24 weitere Personen haben diese Anleitung absolviert.
5 Kommentare
This seems to be a good way to trash the tablet. I couldn't reinsert the large ribbon back into the connector on the left hand side. Ended up breaking the connector. According to another website, there is no need to remove the cable from that end. instead there is a proper lock on the other end which when lifted makes the cable easy to remove and replace from that end! Got to go and buy a new tablet now.
See https://electro-medical.blogspot.co.uk/2... for an alternative way of doing it.
hello, the cable connectors on the top left do not need to disconnect them, as mentioned in steps 3 and 6. To remove the battery simply remove the screws (steps 4 - 5 - 7), disconnect the battery connector (step 9) and remove it from under the flat cable at the top left.
Ne pas enlever le gros ruban ! cette présentation est ratée.
left cable the wider one worked for mine. My tablet is A10 -70F still has Kitkat os. Just make sure you get that ribbon locked down. It took two tries for me to get it all the way back in. If you have no video after replacement the its that ribbon isnt locked in properly. Just be patient and gently tug on it after clamping lock down if it stays put you got it. Good Luck.
