Einleitung
In order to remove the tablet screen, removal of the battery and motherboard is necessary.
Was du brauchst
Use a plastic opening tool to pry open the back cover of the tablet.
The second picture shows the tablet with the back removed.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Remove the tape that secures the ribbon cable.
Use precision tweezers if the tape cannot be removed by hand.
Carefully remove the ribbon cable from the power button connector.
To remove the cable, push the clamp on the connector up and pull gently.
Remove the following screws securing the metal frame holding the battery.
Five 2 mm Philips screws.
Remove the grey tape.
Unscrew the hidden 2mm screw using the Phillips #000 drill bit.
Remove the second piece of tape from the other ribbon cable connected to the battery.
Remove the screws securing the battery connector cover.
Two 2mm Phillips screws.
Remove the following screws using the Phillips 000 drill bit.
Eleven 4 mm screws
Carefully disconnect the ribbon cable on the motherboard.
To remove the cable, push the connector on the clamp up and gently pull.
Disconnect the other end of the motherboard ribbon cable.
The other end is attached to the frame of the tablet with adhesive. Gently pry it up to remove it.
The wire connected to the motherboard can be removed by lifting them from their shown slots.
Remove the pieces of tape attaching the frame of the tablet to the screen
Ten pieces of grey tape.
Remove the screen from the frame of the tablet
Heat up the adhesive and gently pry the screen away with the plastic opening tool.
Separate the screen from the digitizer.
Heat up the adhesive securing the screen and pry it away using the plastic opening tool.
17 weitere Personen haben diese Anleitung absolviert.
6 Kommentare
how did you keep the digitizer intact?my problem is the lcd screen and I bought only that.too scared to start without knowing how to keep the digitizer intact as it would take weeks before I could replace it.also wondering how to replace the lcd and only that.could you help me please?
Hans Sorensen ,Norway
In my personal opinion, this guide have a bunch of steps that aren't necessary. I just replaced a cracked one. And I just removed the battery for security purposes since I was going to use heat. But you don't have to remove the mother board or anything else, just disconnect the digitizer flex and then start prying on front. That's it.
https://youtu.be/etxKSTK3Gno?t=8m19s
Is that black tape important? I wasn't lucky and it was torn.
How do you calibrate the digitizer afterwards?
Step 11 talks about using a Phillips 000 drill bit, rather than screwdriver, to remove the screws.
