Zum Hauptinhalt wechseln
Lenovo Tab 2 A10-70 Rear Facing Camera Replacement
Was du brauchst
  1. Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement, Rear Facing Camera: Schritt 1, Bild 1 von 1
    • Before removing the camera, make sure the device is powered off
    • Use a plastic opening tool to pry open the back cover of the tablet..
  2. Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement: Schritt 2, Bild 1 von 1
    • Locate the cable that is connecting the camera to the tablet
  3. Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the cable that is connecting the camera to the tablet
  4. Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement: Schritt 4, Bild 1 von 2 Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement: Schritt 4, Bild 2 von 2
    • Simply remove the camera from the tablet by lifting it up
    • Repeat Steps in reverse order with a new camera for reassembly
Abschluss
USF Tampa, Team 12-6, Eyestone Spring 2016 Mitglied von USF Tampa, Team 12-6, Eyestone Spring 2016
USFT-EYESTONE-S16S12G6
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 892
