Zum Hauptinhalt wechseln
Lenovo Tab 2 A7-20F Front Glass Replacement
Was du brauchst
  1. Lenovo Tab 2 A7-20F Front Glass Replacement, Case: Schritt 1, Bild 1 von 2 Lenovo Tab 2 A7-20F Front Glass Replacement, Case: Schritt 1, Bild 2 von 2
    • Starting at any point along the seam of the case carefully pry it open with the metal spudger, slowly working your way around the outside until the case can come apart.
  2. Lenovo Tab 2 A7-20F Front Glass Replacement, Battery: Schritt 2, Bild 1 von 2 Lenovo Tab 2 A7-20F Front Glass Replacement, Battery: Schritt 2, Bild 2 von 2
    • The battery is connected to the motherboard by the thin wire shown here.
    • Pull up gently on the yellow tape to access the connector.
  3. Lenovo Tab 2 A7-20F Front Glass Replacement: Schritt 3, Bild 1 von 1
    • Gently detach the connector from the motherboard by pulling up on it.
  4. Lenovo Tab 2 A7-20F Front Glass Replacement: Schritt 4, Bild 1 von 3 Lenovo Tab 2 A7-20F Front Glass Replacement: Schritt 4, Bild 2 von 3 Lenovo Tab 2 A7-20F Front Glass Replacement: Schritt 4, Bild 3 von 3
    • There is double-sided tape inside the case.
    • Use the spudger tool to loosen the bond of the adhesive from the double sided tape.
    • Separate the battery from the case.
  5. Lenovo Tab 2 A7-20F Front Glass Replacement, Motherboard: Schritt 5, Bild 1 von 3 Lenovo Tab 2 A7-20F Front Glass Replacement, Motherboard: Schritt 5, Bild 2 von 3 Lenovo Tab 2 A7-20F Front Glass Replacement, Motherboard: Schritt 5, Bild 3 von 3
    • Use a plastic opening tool or a tweezer to remove any tape.
    • Unplug the electrical connectors by lifting the clip that hold them in place.
    • ''Use the plastic tools first before any metal ones since they can damage the motherboard easily'.'
  6. Lenovo Tab 2 A7-20F Front Glass Replacement: Schritt 6, Bild 1 von 2 Lenovo Tab 2 A7-20F Front Glass Replacement: Schritt 6, Bild 2 von 2
    • Remove the three 2.0mm screws using the Phillips #00 Screwdriver bit.
    • These screws are very small and can be lost easily. The black strip at the top of the motherboard is the speaker and the screws can be placed on that because it is magnetic.
  7. Lenovo Tab 2 A7-20F Front Glass Replacement: Schritt 7, Bild 1 von 3 Lenovo Tab 2 A7-20F Front Glass Replacement: Schritt 7, Bild 2 von 3 Lenovo Tab 2 A7-20F Front Glass Replacement: Schritt 7, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • There are two twisted pairs of wires on the left and right edges of the case.
    • Use a plastic opening tool or tweezers to remove the twisted pairs that are held in place by retaining tabs.
    • These wires lead to objects that need to be carefully lifted from their enclosures at the base of the case using tweezers.
  8. Lenovo Tab 2 A7-20F Front Glass Replacement: Schritt 8, Bild 1 von 3 Lenovo Tab 2 A7-20F Front Glass Replacement: Schritt 8, Bild 2 von 3 Lenovo Tab 2 A7-20F Front Glass Replacement: Schritt 8, Bild 3 von 3
    • After taking out the twisted pairs, there is still one more strip that needs to be removed. It is located off the side of the motherboard and is the piece that receives input for volume and power.
    • Gently lift up the motherboard starting from the right side. The final strip can be removed by gently pulling it up from the case.
    • Remove the motherboard completely from the back panel.
  9. Lenovo Tab 2 A7-20F Front Glass Replacement, Camera Lens: Schritt 9, Bild 1 von 3 Lenovo Tab 2 A7-20F Front Glass Replacement, Camera Lens: Schritt 9, Bild 2 von 3 Lenovo Tab 2 A7-20F Front Glass Replacement, Camera Lens: Schritt 9, Bild 3 von 3
    • The camera lens is located at top left corner of the back panel.
    • Use the plastic opening tool to lift up the camera lens starting from the left side between the gap.
    • Remove the metal tape that connects the camera lens to the panel in order to remove the camera lens.
  10. Lenovo Tab 2 A7-20F Front Glass Replacement, Front Glass: Schritt 10, Bild 1 von 3 Lenovo Tab 2 A7-20F Front Glass Replacement, Front Glass: Schritt 10, Bild 2 von 3 Lenovo Tab 2 A7-20F Front Glass Replacement, Front Glass: Schritt 10, Bild 3 von 3
    • Use the heat gun to loosen the adhesive around the perimeter of the screen(the solid black section).
    • The spudger tools can then be slowly worked under the screen to gradually lift it away from the case.
    • Due to the close proximity of the digitizer to the adhesive, if that component is not being replaced take care not to scratch the screen with the spudger.
    • Under the top section where the Lenovo logo is lies a copper strip that has adhesive on both sides. It is easiest to get under that strip when you start from the bottom and work up.
    • Next step will show the copper strip.
  11. Lenovo Tab 2 A7-20F Front Glass Replacement: Schritt 11, Bild 1 von 2 Lenovo Tab 2 A7-20F Front Glass Replacement: Schritt 11, Bild 2 von 2
    • The first photo shows the strip that lies at the top of the screen.
    • The second photo shows the screen separated from the case with the digitizer already removed.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Thanh
357 Reputation
3 Anleitungen geschrieben
Washington State, Team S5-G111, Phelps-Hillen Fall 2017 Mitglied von Washington State, Team S5-G111, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S5G111
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 1,560
