Einleitung
This guide will explain how to remove the back cover and motherboard on your device in order to access the A/V port. This guide will provide detailed steps for replacement of the A/V port.
Was du brauchst
Place the tablet face down on a soft, stable surface that will protect the screen.
Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
Using the Phillips #000 screwdriver, remove the four M1.4 × 2.5 screws holding the motherboard in place.
Remove the M1.4 × 2.5 screw securing the battery lead to the battery with the Phillips #000 screwdriver.
With a pair of tweezers, gently move the battery lead so it will not obstruct the motherboard.
With a pair of tweezers, carefully unplug the strip connecting the screen to the motherboard.
Remove the motherboard by lifting the top edge and pulling outward to free it from the small tabs that hold it in place.
Flip the motherboard to its back side.
Desolder the six audio/visual port contact points.
Use tweezers to remove the existing audio jack to remove from the motherboard entirely.
Eine weitere Person hat diese Anleitung absolviert.
