Zum Hauptinhalt wechseln
Lenovo Tab 2 A8 MicroUSB Charging Port Replacement
Was du brauchst
  1. Lenovo Tab 2 A8 MicroUSB Charging Port Replacement, Removing the Back Panel: Schritt 1, Bild 1 von 3 Lenovo Tab 2 A8 MicroUSB Charging Port Replacement, Removing the Back Panel: Schritt 1, Bild 2 von 3 Lenovo Tab 2 A8 MicroUSB Charging Port Replacement, Removing the Back Panel: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Place the tablet face down on a soft, stable surface that will protect the screen.
    • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
    • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
    • If the seal covering the screw has already been removed, please proceed to the next step in the process.
    • As the screw is small, you may wish to extract it using a pair of tweezers.
  2. Lenovo Tab 2 A8 MicroUSB Charging Port Replacement: Schritt 2, Bild 1 von 3 Lenovo Tab 2 A8 MicroUSB Charging Port Replacement: Schritt 2, Bild 2 von 3 Lenovo Tab 2 A8 MicroUSB Charging Port Replacement: Schritt 2, Bild 3 von 3
    • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
    • Some force may be required initially to pry the back cover off.
    • Note that the button tabs for this device are loose inside the case and will fall out when opening.
  3. Lenovo Tab 2 A8 MicroUSB Charging Port Replacement, Motherboard: Schritt 3, Bild 1 von 3 Lenovo Tab 2 A8 MicroUSB Charging Port Replacement, Motherboard: Schritt 3, Bild 2 von 3 Lenovo Tab 2 A8 MicroUSB Charging Port Replacement, Motherboard: Schritt 3, Bild 3 von 3
    Kaufen
    • Using the Phillips #000 screwdriver, remove the four M1.4 × 2.5 screws holding the motherboard in place.
    • Because the screws are small, it is a good idea to remove them with a pair of tweezers.
  4. Lenovo Tab 2 A8 MicroUSB Charging Port Replacement: Schritt 4, Bild 1 von 3 Lenovo Tab 2 A8 MicroUSB Charging Port Replacement: Schritt 4, Bild 2 von 3 Lenovo Tab 2 A8 MicroUSB Charging Port Replacement: Schritt 4, Bild 3 von 3
    • Remove the M1.4 × 2.5 screw securing the battery lead to the battery with the Phillips #000 screwdriver.
    • With a pair of tweezers, gently move the battery lead so it will not obstruct the motherboard.
    • With a pair of tweezers, carefully unplug the strip connecting the screen to the motherboard.
    • The strip connecting the screen to the motherboard is firmly in place and may require some careful use of strength to unplug it.
  5. Lenovo Tab 2 A8 MicroUSB Charging Port Replacement: Schritt 5, Bild 1 von 1
    • Remove the motherboard by lifting the top edge and pulling outward to free it from the small tabs that hold it in place.
    • The small tabs can be broken if the motherboard is pried up too forcefully.
    • The button tabs are fastened to the motherboard by a small adhesive strip. Take care in removing the motherboard to avoid tearing the wires.
  6. Lenovo Tab 2 A8 MicroUSB Charging Port Replacement, MicroUSB Charging Port: Schritt 6, Bild 1 von 1
    Kaufen
    • Flip the motherboard on to its back side.
    • The back side has less components on that side. You should see more green color than the front side.
    • Desolder the six soldering joints around the charging port.
    • With a set of tweezers, gentle lift the charging port off motherboard.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
IUPUI, Team 2-4, Baechle Spring 2017 Mitglied von IUPUI, Team 2-4, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G4
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 65
Insgesamt: 12,346
