Einleitung
Use this guide to replace your worn out or dead Lenovo Tab S8 Battery.
If your phone's battery no longer holds charge for as long as you would like or does not function properly, your battery is likely faulty and may need replacement. There are no special skills involved in the replacement of the battery.
Before using this guide, make sure to review the troubleshooting page to ensure that the battery doesn't have any other issues.
Make sure to power off your tablet completely and disconnect from any external power source before beginning the process.
Was du brauchst
Gently insert a spudger into one of the bottom corners between the screen and body case.
Slide the spudger along the inside of the crack in order to pry the case open.
After removing the cover, remove the M1.6 x 2 mm screw from the battery cable with the JIS J000 screwdriver.
Remove the tape by gently scraping the edges up with the spudger.
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
Gently lift the flaps on the four ZIF connectors to disconnect the cables.
Use the plastic card to gently pry the battery from the device.
15 weitere Nutzer:innen haben diese Anleitung absolviert.
