Zum Hauptinhalt wechseln
Lenovo Tab S8 Power Button Replacement
Was du brauchst
  1. Lenovo Tab S8 Power Button Replacement, Power Button: Schritt 1, Bild 1 von 3 Lenovo Tab S8 Power Button Replacement, Power Button: Schritt 1, Bild 2 von 3 Lenovo Tab S8 Power Button Replacement, Power Button: Schritt 1, Bild 3 von 3
    • Make sure the device is powered off
    • Gently insert a spudger into one of the bottom corners between the screen and body case. Gently slide the spudger along the inside of the crack to pry the case open
    • Be careful of the small volume and power buttons when prying the case with the spudger. They are connected with small pieces of plastic that break easily.
  2. Lenovo Tab S8 Power Button Replacement: Schritt 2, Bild 1 von 3 Lenovo Tab S8 Power Button Replacement: Schritt 2, Bild 2 von 3 Lenovo Tab S8 Power Button Replacement: Schritt 2, Bild 3 von 3
    • Gently lift the clear-yellow rubber flap from the plastic pegs with a plastic opening tool.
    • The rubber flap secures the button to the casing, and it falls out easily.
Abschluss
James Albu
608 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 3-6, Eyestone Fall 2015 Mitglied von USF Tampa, Team 3-6, Eyestone Fall 2015
USFT-EYESTONE-F15S3G6
3 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 1,950
