Einleitung
In this guide, you will learn how to properly access each of the speakers within the Lenovo Tab S8 and remove them safely.
Was du brauchst
Gently insert a spudger into one of the bottom corners between the screen and body case.
Slide the spudger along the inside of the crack in order to pry the case open.
After removing the cover, remove the M1.6 x 2 mm screw from the battery cable with the JIS J000 screwdriver.
Remove the tape by gently scraping the edges up with the spudger.
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
Gently lift the flaps on the four ZIF connectors to disconnect the cables.
Use the plastic card to gently pry the battery from the device.
Use the tip of a spudger or your fingernail to flip up the small locking flap. Then, you can safely pull the cable out from under the camera.
Remove the press-fit cable located next to the camera by using opening tool to gently pry it up.
Unlock the ZIF connector by lifting the black bar and sliding the ribbon cable out.
Remove the five M1.6 x 2 mm screws from the motherboard with the JIS J000 screwdriver.
Cut or remove the piece of silver tape from the motherboard.
Once you have removed the motherboard and the battery, locate both the upper and lower speakers.
Lift up the wire with a plastic opening tool. Make sure this tool has a sharp edge.
