Einleitung
This guide will show you how to replace your Lenovo ThinkBook 13s-IML Heat Sink.
The heat sink absorbs heat from the CPU and GPU and disperses it to prevent overheating and heat throttling. A bad heat sink causes permanent hardware failure, so it is important to replace it. If your laptop maintains high idle temperatures, frequent thermal throttling, random shutdowns, or loud fan noise, then it may be time to replace your heat sink.
Before you start your replacement, make sure your laptop is completely shut off and disconnected from any power sources.
Was du brauchst
Remove the nine 4.2 mm-long T5 Torx screws that secure the lower case.
Insert an opening tool into the seam between the lower case and chassis.
Pry around the entire perimeter until the lower case fully releases.
Remove the lower case.
Remove the four 4 mm-long Phillips #00 screws securing the battery.
Use a spudger to push the battery connector out of its socket.
Remove the battery from the computer by pulling it up and out.
Loosen the three M2 x L3mm Phillips #00 screws securing the heat sink.
Gently lift the heat sink up and out.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
