Zum Hauptinhalt wechseln
Lenovo ThinkBook 13S-IML Motherboard Replacement
Was du brauchst
  1. Lenovo ThinkBook 13S-IML Motherboard Replacement, Lower Case: Schritt 1, Bild 1 von 3 Lenovo ThinkBook 13S-IML Motherboard Replacement, Lower Case: Schritt 1, Bild 2 von 3 Lenovo ThinkBook 13S-IML Motherboard Replacement, Lower Case: Schritt 1, Bild 3 von 3
    • Remove the nine 4.2 mm-long T5 Torx screws that secure the lower case.
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry around the entire perimeter until the lower case fully releases.
    • Remove the lower case.
    Frag FixBot
    Kommentar hinzufügen
  2. Lenovo ThinkBook 13S-IML Motherboard Replacement, Fans: Schritt 2, Bild 1 von 3 Lenovo ThinkBook 13S-IML Motherboard Replacement, Fans: Schritt 2, Bild 2 von 3 Lenovo ThinkBook 13S-IML Motherboard Replacement, Fans: Schritt 2, Bild 3 von 3
    • Detach the two sliding fan connectors from the system board by gently pulling them out of their sockets.
    • Use a screwdriver to unscrew the five 3.5 mm Phillips #00 screws that secure the fans in place.
    • Carefully lift the fans out of the system board.
    Frag FixBot
  3. Lenovo ThinkBook 13S-IML Motherboard Replacement, Battery: Schritt 3, Bild 1 von 3 Lenovo ThinkBook 13S-IML Motherboard Replacement, Battery: Schritt 3, Bild 2 von 3 Lenovo ThinkBook 13S-IML Motherboard Replacement, Battery: Schritt 3, Bild 3 von 3
    • Caution: Make sure that your battery is discharged below 25% capacity.
    • Remove the four 4 mm-long Phillips #00 screws securing the battery.
    • Use a spudger to push the battery connector out of its socket.
    • Caution: This may take a while. Be careful, and do not try and push with much force.
    • Remove the battery from the computer by pulling it up and out.
    Frag FixBot
  4. Lenovo ThinkBook 13S-IML Motherboard Replacement, Wi-Fi Card: Schritt 4, Bild 1 von 3 Lenovo ThinkBook 13S-IML Motherboard Replacement, Wi-Fi Card: Schritt 4, Bild 2 von 3 Lenovo ThinkBook 13S-IML Motherboard Replacement, Wi-Fi Card: Schritt 4, Bild 3 von 3
    • Use tweezers ore the pointed end of a spudger to lift and disconnect the two Wi-Fi card antenna connectors.
    • Remove the 2 mm-long Phillips #00 screw securing the Wi-Fi card down.
    • Slide the Wi-Fi card out of its socket.
    Frag FixBot
  5. Lenovo ThinkBook 13S-IML Motherboard Replacement, RAM: Schritt 5, Bild 1 von 2 Lenovo ThinkBook 13S-IML Motherboard Replacement, RAM: Schritt 5, Bild 2 von 2
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    • Slide the RAM module out of its socket.
    Frag FixBot
  6. Lenovo ThinkBook 13S-IML Motherboard Replacement, Solid-State Drive (SSD): Schritt 6, Bild 1 von 2 Lenovo ThinkBook 13S-IML Motherboard Replacement, Solid-State Drive (SSD): Schritt 6, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the 5.4 mm-long screw securing the SSD.
    • Pull the SSD directly out of its socket.
    Frag FixBot
  7. Lenovo ThinkBook 13S-IML Motherboard Replacement, Heat Sink: Schritt 7, Bild 1 von 3 Lenovo ThinkBook 13S-IML Motherboard Replacement, Heat Sink: Schritt 7, Bild 2 von 3 Lenovo ThinkBook 13S-IML Motherboard Replacement, Heat Sink: Schritt 7, Bild 3 von 3
    • Loosen the three M2 x L3mm Phillips #00 screws securing the heat sink.
    • Gently lift the heat sink up and out.
    • Be sure to reapply thermal paste before installing a new heat sink.
    Frag FixBot
  8. Lenovo ThinkBook 13S-IML Motherboard Replacement, Motherboard: Schritt 8, Bild 1 von 1
    • Remove the six M2.5 x 5mm Phillips #00 screws that secure the upper case hinges first.
    • Remove the two remaining M2 x 5mm Phillips #00 screws and set them aside.
    Frag FixBot
  9. Lenovo ThinkBook 13S-IML Motherboard Replacement: Schritt 9, Bild 1 von 2 Lenovo ThinkBook 13S-IML Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Pull back on the metal tabs connected to the hinge.
    • Depending on the state of the laptop case, this might be difficult to remove. It may be easier to open the laptop rather than pulling open the hinges.
    Frag FixBot
  10. Lenovo ThinkBook 13S-IML Motherboard Replacement: Schritt 10, Bild 1 von 2 Lenovo ThinkBook 13S-IML Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Remove all the following connectors before removing the screws from the motherboard:
    • ZIF connector.
    • Blue ribbon cable connector.
    • Sliding connector.
    • Remove the 5 4mm-long Phillips #00 screws holding down the motherboard.
    • It is easy to miss the screw below the black tape, remove this one first so you don't forget.
    Frag FixBot
  11. Lenovo ThinkBook 13S-IML Motherboard Replacement: Schritt 11, Bild 1 von 2 Lenovo ThinkBook 13S-IML Motherboard Replacement: Schritt 11, Bild 2 von 2
    • With all screws out, carefully remove the motherboard as shown, pulling toward the area of the power button (boxed in red).
    Frag FixBot
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Samson BeSerra
289 Reputation
3 Anleitungen geschrieben
UW Tacoma, Team E-2, Rose Winter 2026 Mitglied von UW Tacoma, Team E-2, Rose Winter 2026
UWT-ROSE-W26SEG2
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 58
Insgesamt: 179
