Zum Hauptinhalt wechseln
Lenovo ThinkBook 13S-IML Power Button Replacement
Was du brauchst
  1. Lenovo ThinkBook 13S-IML Power Button Replacement, Lower Case: Schritt 1, Bild 1 von 3 Lenovo ThinkBook 13S-IML Power Button Replacement, Lower Case: Schritt 1, Bild 2 von 3 Lenovo ThinkBook 13S-IML Power Button Replacement, Lower Case: Schritt 1, Bild 3 von 3
    • Remove the nine 4.2 mm-long T5 Torx screws that secure the lower case.
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry around the entire perimeter until the lower case fully releases.
    • Remove the lower case.
    Frag FixBot
    Kommentar hinzufügen
  2. Lenovo ThinkBook 13S-IML Power Button Replacement, Battery: Schritt 2, Bild 1 von 3 Lenovo ThinkBook 13S-IML Power Button Replacement, Battery: Schritt 2, Bild 2 von 3 Lenovo ThinkBook 13S-IML Power Button Replacement, Battery: Schritt 2, Bild 3 von 3
    • Caution: Make sure that your battery is discharged below 25% capacity.
    • Remove the four 4 mm-long Phillips #00 screws securing the battery.
    • Use a spudger to push the battery connector out of its socket.
    • Caution: This may take a while. Be careful, and do not try and push with much force.
    • Remove the battery from the computer by pulling it up and out.
    Frag FixBot
  3. Lenovo ThinkBook 13S-IML Power Button Replacement, Power Button: Schritt 3, Bild 1 von 1
    • Remove the six M2.5 x 5 Phillips #00 screws that secure the upper case hinges first.
    • Remove the two remaining M2 x 5 Phillips #00 screws and set them aside.
    Frag FixBot
  4. Lenovo ThinkBook 13S-IML Power Button Replacement: Schritt 4, Bild 1 von 2 Lenovo ThinkBook 13S-IML Power Button Replacement: Schritt 4, Bild 2 von 2
    • Carefully open laptop to pull upper case hinges apart from the board.
    • It may be easier to open the laptop rather than pulling open the hinges.
    Frag FixBot
  5. Lenovo ThinkBook 13S-IML Power Button Replacement: Schritt 5, Bild 1 von 1
    • Remove the 2 M2.0 x 3.5mm Phillips #00 screws.
    • Locate the larger ZIF connector and lift the circled locking flap, then pull the cable out of its socket.
    • Proceed to lift the USB board out.
    Frag FixBot
  6. Lenovo ThinkBook 13S-IML Power Button Replacement: Schritt 6, Bild 1 von 3 Lenovo ThinkBook 13S-IML Power Button Replacement: Schritt 6, Bild 2 von 3 Lenovo ThinkBook 13S-IML Power Button Replacement: Schritt 6, Bild 3 von 3
    • Carefully pull up the plastic power button cover.
    • Disengage the thin ZIF connector by flipping up the locking flap and pulling the cable out of it's socket.
    • Proceed to remove the power button.
    Frag FixBot
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Samson BeSerra
289 Reputation
3 Anleitungen geschrieben
UW Tacoma, Team E-2, Rose Winter 2026 Mitglied von UW Tacoma, Team E-2, Rose Winter 2026
UWT-ROSE-W26SEG2
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 32
Insgesamt: 119
