Einleitung
Use this guide to replace/upgrade the RAM in a Lenovo ThinkBook 13S-IML.
Was du brauchst
Remove the nine 4.2 mm-long T5 Torx screws that secure the lower case.
Insert an opening tool into the seam between the lower case and chassis.
Pry around the entire perimeter until the lower case fully releases.
Remove the lower case.
Remove the four 4 mm-long Phillips #00 screws securing the battery.
Use a spudger to push the battery connector out of its socket.
Remove the battery from the computer by pulling it up and out.
Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
Slide the RAM module out of its socket.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
