Zum Hauptinhalt wechseln
Lenovo ThinkBook 13S-IML Wi-Fi Card Replacement
Was du brauchst
  1. Lenovo ThinkBook 13S-IML Wi-Fi Card Replacement, Lower Case: Schritt 1, Bild 1 von 3 Lenovo ThinkBook 13S-IML Wi-Fi Card Replacement, Lower Case: Schritt 1, Bild 2 von 3 Lenovo ThinkBook 13S-IML Wi-Fi Card Replacement, Lower Case: Schritt 1, Bild 3 von 3
    • Remove the nine 4.2 mm-long T5 Torx screws that secure the lower case.
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry around the entire perimeter until the lower case fully releases.
    • Remove the lower case.
    Frag FixBot
    Kommentar hinzufügen
  2. Lenovo ThinkBook 13S-IML Wi-Fi Card Replacement, Battery: Schritt 2, Bild 1 von 3 Lenovo ThinkBook 13S-IML Wi-Fi Card Replacement, Battery: Schritt 2, Bild 2 von 3 Lenovo ThinkBook 13S-IML Wi-Fi Card Replacement, Battery: Schritt 2, Bild 3 von 3
    • Caution: Make sure that your battery is discharged below 25% capacity.
    • Remove the four 4 mm-long Phillips #00 screws securing the battery.
    • Use a spudger to push the battery connector out of its socket.
    • Caution: This may take a while. Be careful, and do not try and push with much force.
    • Remove the battery from the computer by pulling it up and out.
    Frag FixBot
  3. Lenovo ThinkBook 13S-IML Wi-Fi Card Replacement, Wi-Fi Card: Schritt 3, Bild 1 von 3 Lenovo ThinkBook 13S-IML Wi-Fi Card Replacement, Wi-Fi Card: Schritt 3, Bild 2 von 3 Lenovo ThinkBook 13S-IML Wi-Fi Card Replacement, Wi-Fi Card: Schritt 3, Bild 3 von 3
    • Use tweezers ore the pointed end of a spudger to lift and disconnect the two Wi-Fi card antenna connectors.
    • Remove the 2 mm-long Phillips #00 screw securing the Wi-Fi card down.
    • Slide the Wi-Fi card out of its socket.
    Frag FixBot
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Connor Bassolino
25.051 Reputation
125 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 21
Insgesamt: 55
