Zum Hauptinhalt wechseln
Lenovo ThinkBook 13s-IML Battery Replacement
Was du brauchst
  1. Lenovo ThinkBook 13s-IML Battery Replacement, Lower Case: Schritt 1, Bild 1 von 3 Lenovo ThinkBook 13s-IML Battery Replacement, Lower Case: Schritt 1, Bild 2 von 3 Lenovo ThinkBook 13s-IML Battery Replacement, Lower Case: Schritt 1, Bild 3 von 3
    • Remove the nine 4.2 mm-long T5 Torx screws that secure the lower case.
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry around the entire perimeter until the lower case fully releases.
    • Remove the lower case.
    Frag FixBot
    Kommentar hinzufügen
  2. Lenovo ThinkBook 13s-IML Battery Replacement, Battery: Schritt 2, Bild 1 von 3 Lenovo ThinkBook 13s-IML Battery Replacement, Battery: Schritt 2, Bild 2 von 3 Lenovo ThinkBook 13s-IML Battery Replacement, Battery: Schritt 2, Bild 3 von 3
    • Caution: Make sure that your battery is discharged below 25% capacity.
    • Remove the four 4 mm-long Phillips #00 screws securing the battery.
    • Use a spudger to push the battery connector out of its socket.
    • Caution: This may take a while. Be careful, and do not try and push with much force.
    • Remove the battery from the computer by pulling it up and out.
    Frag FixBot
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 12
Letzte 7 Tage: 24
Letzte 30 Tage: 89
Insgesamt: 550
