Einleitung
This is a guide to remove the back cover of your Lenovo ThinkBook 15 G2 ITL. It is a mandatory pre-requisite to work on the internals of the laptop.
Was du brauchst
Place the computer upside down on a flat surface.
Remove ten 5mm screws with the Phillips #00 screwdriver.
Pry up the latches using an opening pick.
Remove the lower case to show the internal components of the computer.
