Zum Hauptinhalt wechseln
Lenovo ThinkBook 15 G2 ITL Speaker Replacement
Was du brauchst
  1. Lenovo ThinkBook 15 G2 ITL Speaker Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Make sure the computer has been shut down before proceeding.
    • Place the computer upside down on a flat surface.
    • Remove ten 5mm screws with the Phillips #00 screwdriver.
    Frag FixBot
    Kommentar hinzufügen
  2. Lenovo ThinkBook 15 G2 ITL Speaker Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkBook 15 G2 ITL Speaker Replacement: Schritt 2, Bild 2 von 2
    • Pry up the latches using an opening pick.
    • Remove the lower case to show the internal components of the computer.
    Frag FixBot
  3. Lenovo ThinkBook 15 G2 ITL Speaker Replacement, Battery: Schritt 3, Bild 1 von 3 Lenovo ThinkBook 15 G2 ITL Speaker Replacement, Battery: Schritt 3, Bild 2 von 3 Lenovo ThinkBook 15 G2 ITL Speaker Replacement, Battery: Schritt 3, Bild 3 von 3
    • Disconnect the battery pack cable from the system board.
    • Use your fingernails to pull the connector to unplug it. Do not pull the cable.
    • Remove the four 5mm screws with the Phillips #00 screwdriver.
    • Gently pry and remove the battery pack.
    Frag FixBot
  4. Lenovo ThinkBook 15 G2 ITL Speaker Replacement, Speaker: Schritt 4, Bild 1 von 3 Lenovo ThinkBook 15 G2 ITL Speaker Replacement, Speaker: Schritt 4, Bild 2 von 3 Lenovo ThinkBook 15 G2 ITL Speaker Replacement, Speaker: Schritt 4, Bild 3 von 3
    • Gently pull the speaker cable connector straight out from its socket on the motherboard.
    • Lift the speaker straight up and out of the laptop.
    Frag FixBot
Abschluss
Alondra Hernandez
157 Reputation
2 Anleitungen geschrieben
Austin Community College, Team 1-3, Anderson Spring 2026 Mitglied von Austin Community College, Team 1-3, Anderson Spring 2026
AUSTINCC-ANDERSON-S26S1G3
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 30
Insgesamt: 87
