Einleitung
If your Lenovo ThinkBook 15 G2 ITL (20VE00QESA) trackpad is glitching or not working, this guide shows how to replace it. The trackpad is crucial to the functioning of the laptop. When it begins to fail you may experience glitching, unresponsiveness, and sensitivity problems.
Before beginning, make sure to power off your laptop completely and disconnect from any external power source.
Was du brauchst
Place the computer upside down on a flat surface.
Remove ten 5mm screws with the Phillips #00 screwdriver.
Pry up the latches using an opening pick.
Remove the lower case to show the internal components of the computer.
Disconnect the battery pack cable from the system board.
Remove the four 5mm screws with the Phillips #00 screwdriver.
Gently pry and remove the battery pack.
Remove the four 5 mm screws using a Phillips #00 screwdriver.
Gently pull the ribbon cable out using your fingers.
Gently peel off the tape.
Remove the trackpad.
