Zum Hauptinhalt wechseln
Lenovo ThinkCentre M92p Hard Drive Replacement
Was du brauchst
  1. Lenovo ThinkCentre M92p Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 3 Lenovo ThinkCentre M92p Hard Drive Replacement, Hard Drive: Schritt 1, Bild 2 von 3 Lenovo ThinkCentre M92p Hard Drive Replacement, Hard Drive: Schritt 1, Bild 3 von 3
    • Power off your ThinkCentre M92p, and unplug the power cable from the electrical outlet.
  2. Lenovo ThinkCentre M92p Hard Drive Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkCentre M92p Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Using a Phillips #1 screwdriver, remove the middle black screw located on the back of the ThinkCentre.
  3. Lenovo ThinkCentre M92p Hard Drive Replacement: Schritt 3, Bild 1 von 3 Lenovo ThinkCentre M92p Hard Drive Replacement: Schritt 3, Bild 2 von 3 Lenovo ThinkCentre M92p Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Use your thumbs and slide the metal housing towards the front, to remove the cover.
  4. Lenovo ThinkCentre M92p Hard Drive Replacement: Schritt 4, Bild 1 von 2 Lenovo ThinkCentre M92p Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Unplug the black connector from the damaged hard drive.
  5. Lenovo ThinkCentre M92p Hard Drive Replacement: Schritt 5, Bild 1 von 3 Lenovo ThinkCentre M92p Hard Drive Replacement: Schritt 5, Bild 2 von 3 Lenovo ThinkCentre M92p Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Use the Phillips #1 screwdriver to remove the two black screws holding the hard drive to the chassis.
  6. Lenovo ThinkCentre M92p Hard Drive Replacement: Schritt 6, Bild 1 von 3 Lenovo ThinkCentre M92p Hard Drive Replacement: Schritt 6, Bild 2 von 3 Lenovo ThinkCentre M92p Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Do not try to remove the hard drive right away .There is a red/black cable connected to the motherboard, right below the hard drive. Gently disconnect it from the *green* motherboard***.
  7. Lenovo ThinkCentre M92p Hard Drive Replacement: Schritt 7, Bild 1 von 3 Lenovo ThinkCentre M92p Hard Drive Replacement: Schritt 7, Bild 2 von 3 Lenovo ThinkCentre M92p Hard Drive Replacement: Schritt 7, Bild 3 von 3
    • Flip over the disconnected caddy/tray and use the Phillips #1 screwdriver to remove the four screws from the bottom. Then remove the hard drive.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
York University, Team 1-3, O'Regan Fall 2021 Mitglied von York University, Team 1-3, O'Regan Fall 2021
YORK-O'REGAN-F21S1G3
1 Mitglied
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 28
Letzte 30 Tage: 131
Insgesamt: 5,253
