Einleitung
This guide will show you how to replace the RAM in your Lenovo ThinkPad E570 RAM laptop. Is your device showing random crashes or reboots, crashing during heavy memory use tasks (such as gaming or Photoshop), memory or processing errors appearing on screen, failure to boot (or turn on), and/or repeated long beeps? If so, your device needs RAM replacement or addition. Replacing/adding RAM to your device will help to prevent your laptop from frequent crashes or reboots and avoid processing and memory errors. Replacing/adding RAM will ensure your device runs smoothly and can keep up with every program you need to use.
Power down your laptop and disconnect from any external power sources before beginning this guide.
Was du brauchst
Unscrew two captive 5 mm screws from the back panel of the laptop using a Phillips #00 screwdriver.
Carefully remove the back panel.
Push the small silver latches on either side of the RAM outwards.
Lift the RAM out of the laptop.
Repeat this step for the second stick of RAM, if applicable.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
