Zum Hauptinhalt wechseln
Lenovo ThinkPad Edge E420s Fan Replacement
Was du brauchst
  1. Lenovo ThinkPad Edge E420s Fan Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • There is no external access to the battery. Please make sure the at the battery has been drained or disabled through BIOS before beginning.
    • Flip the device over.
  2. Lenovo ThinkPad Edge E420s Fan Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove one M2 x 3mm screw from the side of the device.
  3. Lenovo ThinkPad Edge E420s Fan Replacement: Schritt 3, Bild 1 von 3 Lenovo ThinkPad Edge E420s Fan Replacement: Schritt 3, Bild 2 von 3 Lenovo ThinkPad Edge E420s Fan Replacement: Schritt 3, Bild 3 von 3
    • Swing the cover out slightly like a hinge.
    • Pull the cover directly away from the case towards the base of the laptop.
    • Lift the cover up and away from the device to remove it.
    • You may hear a slight pop when you pull the cover off.
  4. Lenovo ThinkPad Edge E420s Fan Replacement: Schritt 4, Bild 1 von 1
    • Use the clear tab to slide the hard drive out of the device.
  5. Lenovo ThinkPad Edge E420s Fan Replacement: Schritt 5, Bild 1 von 3 Lenovo ThinkPad Edge E420s Fan Replacement: Schritt 5, Bild 2 von 3 Lenovo ThinkPad Edge E420s Fan Replacement: Schritt 5, Bild 3 von 3
    • To replace the hard drive, remove the four M2 × 4mm wafer-headed screws on the sides of the hard drive case using a Phillips #00 screwdriver.
    • Slide the old hard drive directly out.
    • When reassembling, make sure the hard drive is securely in the case before beginning.
  6. Lenovo ThinkPad Edge E420s Fan Replacement, Top Case: Schritt 6, Bild 1 von 2 Lenovo ThinkPad Edge E420s Fan Replacement, Top Case: Schritt 6, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove eight M2 × 3 mm screws near the front opening and scattered across the bottom of the laptop.
    • Remove three M2x3 mm screws using a Phillips #00 screwdriver from the base of the laptop near the opening.
  7. Lenovo ThinkPad Edge E420s Fan Replacement: Schritt 7, Bild 1 von 1
    • Remove the M3 x 2mm screw from the hole left by the hard drive using a Phillips #00 screwdriver.
  8. Lenovo ThinkPad Edge E420s Fan Replacement: Schritt 8, Bild 1 von 2 Lenovo ThinkPad Edge E420s Fan Replacement: Schritt 8, Bild 2 von 2
    • Flip over the device.
    • Open the device normally.
  9. Lenovo ThinkPad Edge E420s Fan Replacement: Schritt 9, Bild 1 von 1
    • Wedge the plastic opening tool between the upper and lower halves of the lower case.
    • Lift the end of the opening tool slowly until the case separates.
    • Hearing a small popping or cracking noise during this step is normal
  10. Lenovo ThinkPad Edge E420s Fan Replacement: Schritt 10, Bild 1 von 1
    • Lift the upper half of the case up slowly.
    • Be sure not to yank any of the wires connected to the case as this could damage them.
  11. Lenovo ThinkPad Edge E420s Fan Replacement: Schritt 11, Bild 1 von 3 Lenovo ThinkPad Edge E420s Fan Replacement: Schritt 11, Bild 2 von 3 Lenovo ThinkPad Edge E420s Fan Replacement: Schritt 11, Bild 3 von 3
    • Locate and disconnect the 4 ribbon wires from the top case.
    • Locate and disconnect the two additional connecting wires.
    • Some wires may be connected by a clamp. In order to remove the clamp, press upwards on the lever attached to the connector
    • Be careful to not yank on the wires when disconnecting them as they are easily damaged.
  12. Lenovo ThinkPad Edge E420s Fan Replacement: Schritt 12, Bild 1 von 1
    • Lift the unattached case away from the device and place it to the side.
    • When reassembling ensure that all parts of the case are properly aligned.
  13. Lenovo ThinkPad Edge E420s Fan Replacement, Optical Drive: Schritt 13, Bild 1 von 2 Lenovo ThinkPad Edge E420s Fan Replacement, Optical Drive: Schritt 13, Bild 2 von 2
    • Remove the two M2 x 3mm securing the the optical drive to the device using a Phillips #000 screwdriver.
  14. Lenovo ThinkPad Edge E420s Fan Replacement: Schritt 14, Bild 1 von 1
    • Slide the optical drive away from the motherboard in order to remove it.
  15. Lenovo ThinkPad Edge E420s Fan Replacement, Fan: Schritt 15, Bild 1 von 1
    • Use a Phillips #0 screwdriver to remove the four M2 x 6mm screws connecting the heatsink to the motherboard.
  16. Lenovo ThinkPad Edge E420s Fan Replacement: Schritt 16, Bild 1 von 2 Lenovo ThinkPad Edge E420s Fan Replacement: Schritt 16, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the two M2 x 3mm screws from the fan.
  17. Lenovo ThinkPad Edge E420s Fan Replacement: Schritt 17, Bild 1 von 2 Lenovo ThinkPad Edge E420s Fan Replacement: Schritt 17, Bild 2 von 2
    • Disconnect the cable connecting the fan to the motherboard, then remove the fan and the attached fan component from the case.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 8
Insgesamt: 394
