Einleitung
If you need to replace the keyboard, use this guide to access and remove the keyboard from this device. For this guide you will need a plastic opening tool, a Phillips #0 and Phillips #00 screwdriver. This repair may be needed either as a prerequisite to replacing other parts or in order to fix issues such as frequent, but irregular crashes, error messages, or disappearing or scrambled files.
Was du brauchst
Use a Phillips #00 screwdriver to remove one M2 x 3mm screw from the side of the device.
Swing the cover out slightly like a hinge.
Pull the cover directly away from the case towards the base of the laptop.
Lift the cover up and away from the device to remove it.
To replace the hard drive, remove the four M2 × 4mm wafer-headed screws on the sides of the hard drive case using a Phillips #00 screwdriver.
Slide the old hard drive directly out.
Use a Phillips #0 screwdriver to remove eight M2 × 3 mm screws near the front opening and scattered across the bottom of the laptop.
Remove three M2x3 mm screws using a Phillips #00 screwdriver from the base of the laptop near the opening.
Remove the M3 x 2mm screw from the hole left by the hard drive using a Phillips #00 screwdriver.
Wedge the plastic opening tool between the upper and lower halves of the lower case.
Lift the end of the opening tool slowly until the case separates.
Locate and disconnect the 4 ribbon wires from the top case.
Locate and disconnect the two additional connecting wires.
Take the top case and turn it over so you can see the back of the keyboard.
Use a plastic opening tool to push out the metal spacers holding the keyboard in place.
