Zum Hauptinhalt wechseln
Lenovo ThinkPad Edge E520 CD Disk Drive Replacement
Was du brauchst
  1. Lenovo ThinkPad Edge E520 CD Disk Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power off and unplug the computer before the start of these steps.
    • Close the laptop lid.
  2. Lenovo ThinkPad Edge E520 CD Disk Drive Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad Edge E520 CD Disk Drive Replacement: Schritt 2, Bild 2 von 2
    • Flip the computer so that the back is facing upwards.
    • Locate the switch used to release the battery.
    • The switch should be located towards the hinge of the laptop near the battery pack and have a lock icon associated with it.
  3. Lenovo ThinkPad Edge E520 CD Disk Drive Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad Edge E520 CD Disk Drive Replacement: Schritt 3, Bild 2 von 2
    • Slide the switch towards the unlocked lock icon.
    • While holding it in the unlocked position, slide the battery towards the hinge.
    • Fully separate the battery pack from the back of the laptop.
  4. Lenovo ThinkPad Edge E520 CD Disk Drive Replacement, Back Plate: Schritt 4, Bild 1 von 2 Lenovo ThinkPad Edge E520 CD Disk Drive Replacement, Back Plate: Schritt 4, Bild 2 von 2
    • Flip over the laptop and position it with the battery being furthest away from you.
    • Remove the four screws on the edges of the T-Shaped plate with a Phillips #0 screwdriver.
    • Remove the T-Shaped plate from the back of the computer. It should come off easily if all four aforementioned screws are removed.
    • Screw length 6.35 mm, head 3.175 mm
  5. Lenovo ThinkPad Edge E520 CD Disk Drive Replacement, Keyboard: Schritt 5, Bild 1 von 1
    • Remove the battery from the back of the device
    • Unscrew the two 3.175 mm diameter and 6.35 mm length screws with keyboard symbols pointing at them using a Phillips head screwdriver.
  6. Lenovo ThinkPad Edge E520 CD Disk Drive Replacement: Schritt 6, Bild 1 von 3 Lenovo ThinkPad Edge E520 CD Disk Drive Replacement: Schritt 6, Bild 2 von 3 Lenovo ThinkPad Edge E520 CD Disk Drive Replacement: Schritt 6, Bild 3 von 3
    • Turn the laptop back over so that the keyboard is facing you.
    • Use your hands to separate the keyboard from the laptop
  7. Lenovo ThinkPad Edge E520 CD Disk Drive Replacement, Front Compartment Case: Schritt 7, Bild 1 von 1
    • Remove all remaining screws on the back of the device.
    • Screw length 6.35 mm, head 3.175 mm Screws behind battery length 3.175 mm, head 3.175 mm
  8. Lenovo ThinkPad Edge E520 CD Disk Drive Replacement: Schritt 8, Bild 1 von 3 Lenovo ThinkPad Edge E520 CD Disk Drive Replacement: Schritt 8, Bild 2 von 3 Lenovo ThinkPad Edge E520 CD Disk Drive Replacement: Schritt 8, Bild 3 von 3
    • Flip device back over and open the screen.
    • Insert the prying tool on one edge of the case and follow along all four edges until the case frees up.
    • Remove the case.
  9. Lenovo ThinkPad Edge E520 CD Disk Drive Replacement, CD Disk Drive: Schritt 9, Bild 1 von 2 Lenovo ThinkPad Edge E520 CD Disk Drive Replacement, CD Disk Drive: Schritt 9, Bild 2 von 2
    • The silver block contains two screws.
    • Unscrew the two screws to remove the clamp that holds the disk drive in place.
    • Remove the screws holding the disk drive in place and then slide outwards to remove
Abschluss
Andrew Martin
202 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S1-G2, Simcock Spring 2018 Mitglied von UMass Dartmouth, Team S1-G2, Simcock Spring 2018
UMASSD-SIMCOCK-S18S1G2
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 366
