Einleitung
This guide will help to replace the front compartment case of the Lenovo Thinkpad Edge E520.
Was du brauchst
Flip the computer so that the back is facing upwards.
Locate the switch used to release the battery.
Slide the switch towards the unlocked lock icon.
While holding it in the unlocked position, slide the battery towards the hinge.
Fully separate the battery pack from the back of the laptop.
Flip over the laptop and position it with the battery being furthest away from you.
Remove the four screws on the edges of the T-Shaped plate with a Phillips #0 screwdriver.
Remove the T-Shaped plate from the back of the computer. It should come off easily if all four aforementioned screws are removed.
Unscrew the two 3.175 mm diameter and 6.35 mm length screws with keyboard symbols pointing at them using a Phillips head screwdriver.
Turn the laptop back over so that the keyboard is facing you.
Use your hands to separate the keyboard from the laptop
Remove all remaining screws on the back of the device.
Screw length 6.35 mm, head 3.175 mm Screws behind battery length 3.175 mm, head 3.175 mm
Flip device back over and open the screen.
Insert the prying tool on one edge of the case and follow along all four edges until the case frees up.
Remove the case.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
