Zum Hauptinhalt wechseln
Lenovo ThinkPad Edge E520 Hard Drive Replacement
Was du brauchst
  1. Lenovo ThinkPad Edge E520 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power off and unplug the computer before the start of these steps.
    • Close the laptop lid.
  2. Lenovo ThinkPad Edge E520 Hard Drive Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad Edge E520 Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Flip the computer so that the back is facing upwards.
    • Locate the switch used to release the battery.
    • The switch should be located towards the hinge of the laptop near the battery pack and have a lock icon associated with it.
  3. Lenovo ThinkPad Edge E520 Hard Drive Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad Edge E520 Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Slide the switch towards the unlocked lock icon.
    • While holding it in the unlocked position, slide the battery towards the hinge.
    • Fully separate the battery pack from the back of the laptop.
  4. Lenovo ThinkPad Edge E520 Hard Drive Replacement, Back Plate: Schritt 4, Bild 1 von 2 Lenovo ThinkPad Edge E520 Hard Drive Replacement, Back Plate: Schritt 4, Bild 2 von 2
    • Flip over the laptop and position it with the battery being furthest away from you.
    • Remove the four screws on the edges of the T-Shaped plate with a Phillips #0 screwdriver.
    • Remove the T-Shaped plate from the back of the computer. It should come off easily if all four aforementioned screws are removed.
    • Screw length 6.35 mm, head 3.175 mm
  5. Lenovo ThinkPad Edge E520 Hard Drive Replacement, Hard Drive: Schritt 5, Bild 1 von 3 Lenovo ThinkPad Edge E520 Hard Drive Replacement, Hard Drive: Schritt 5, Bild 2 von 3 Lenovo ThinkPad Edge E520 Hard Drive Replacement, Hard Drive: Schritt 5, Bild 3 von 3
    • Position the laptop so that the battery compartment is facing away from you.
    • Remove the two bracket screws on the bottom of the hard drive.
    • Gently lift out the hard drive with its bracket still attached.
    • Remove the bracket from the hard drive.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
David Skarbek
271 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S1-G2, Simcock Spring 2018 Mitglied von UMass Dartmouth, Team S1-G2, Simcock Spring 2018
UMASSD-SIMCOCK-S18S1G2
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 1,409
