Zum Hauptinhalt wechseln
Einleitung
This guide will assist you in replacement of the Lenovo Thinkpad Edge E520 keyboard. You will require a Phillips head screwdriver for this replacement.
Ersatzteile
Keine Ersatzteile angegeben.
  1. There are two screws that have keyboard symbols pointing at them.
    • There are two screws that have keyboard symbols pointing at them.
    • Unscrew the screws with a 3.175 mm diameter and 6.35 mm length with a Phillips head screwdriver.
  2. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  3. Turn the laptop back over so that the keyboard is facing you. Use your hands to separate the keyboard from the laptop Use your hands to separate the keyboard from the laptop
    • Turn the laptop back over so that the keyboard is facing you.
    • Use your hands to separate the keyboard from the laptop
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Holly Dunham
384 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S1-G2, Simcock Spring 2018 Mitglied von UMass Dartmouth, Team S1-G2, Simcock Spring 2018
UMASSD-SIMCOCK-S18S1G2
4 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 158
