Zum Hauptinhalt wechseln
Lenovo ThinkPad Edge E520 RAM Replacement
Was du brauchst
  1. Lenovo ThinkPad Edge E520 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power off and unplug the computer before the start of these steps.
    • Close the laptop lid.
  2. Lenovo ThinkPad Edge E520 RAM Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad Edge E520 RAM Replacement: Schritt 2, Bild 2 von 2
    • Flip the computer so that the back is facing upwards.
    • Locate the switch used to release the battery.
    • The switch should be located towards the hinge of the laptop near the battery pack and have a lock icon associated with it.
  3. Lenovo ThinkPad Edge E520 RAM Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad Edge E520 RAM Replacement: Schritt 3, Bild 2 von 2
    • Slide the switch towards the unlocked lock icon.
    • While holding it in the unlocked position, slide the battery towards the hinge.
    • Fully separate the battery pack from the back of the laptop.
  4. Lenovo ThinkPad Edge E520 RAM Replacement, Back Plate: Schritt 4, Bild 1 von 2 Lenovo ThinkPad Edge E520 RAM Replacement, Back Plate: Schritt 4, Bild 2 von 2
    • Flip over the laptop and position it with the battery being furthest away from you.
    • Remove the four screws on the edges of the T-Shaped plate with a Phillips #0 screwdriver.
    • Remove the T-Shaped plate from the back of the computer. It should come off easily if all four aforementioned screws are removed.
    • Screw length 6.35 mm, head 3.175 mm
  5. Lenovo ThinkPad Edge E520 RAM Replacement, RAM: Schritt 5, Bild 1 von 1
    • The blue tinted rectangular chips will be located opposite of the hinge.
    • They are stacked on top of one another and the second chip will be found underneath the top one.
  6. Lenovo ThinkPad Edge E520 RAM Replacement: Schritt 6, Bild 1 von 2 Lenovo ThinkPad Edge E520 RAM Replacement: Schritt 6, Bild 2 von 2
    • Locate the two thin metal tracks that hold each RAM in place.
    • Using light pressure, press the tracks outward and the RAM should pop up.
  7. Lenovo ThinkPad Edge E520 RAM Replacement: Schritt 7, Bild 1 von 1
    • A light pull on the RAM should remove it with no issues.
    • Repeat from the second step to the third step to remove the second chip.
    • On reassembly, the RAM may provide some difficulty to put it back in. Be patient and slide the ram back in the metal track and apply pressure to make sure that it is in.
    • Be sure that it is in the track so the pins do not bend. A "click" sound may be heard to indicate when it is fully seated.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Andrew Martin
202 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S1-G2, Simcock Spring 2018 Mitglied von UMass Dartmouth, Team S1-G2, Simcock Spring 2018
UMASSD-SIMCOCK-S18S1G2
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 20
Insgesamt: 996
