Zum Hauptinhalt wechseln
Einleitung
How to change / upgrade SDRAM Memory
How to fully disassemble Lenovo ThinkPad E530 - Video manual:
Einführungsvideo
  1. Switch-off the Laptop and remove the battery. The HDD/Memory Cover is held by 3x Phillips screws. Remove them. Remove the Cover.
    • Switch-off the Laptop and remove the battery.
    • The HDD/Memory Cover is held by 3x Phillips screws. Remove them.
    • Remove the Cover.
  2. This model has 2x slots for SODIMM SDRAM. For ThinkPad Edge E530 you can install 2x modules DDR3 SODIMM up to 16GB. For ThinkPad Edge E530c you can install 2x modules DDR3 SODIMM up to 8GB.
    • This model has 2x slots for SODIMM SDRAM.
    • For ThinkPad Edge E530 you can install 2x modules DDR3 SODIMM up to 16GB.
    • For ThinkPad Edge E530c you can install 2x modules DDR3 SODIMM up to 8GB.
    • Did you do it successfully?
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
ZFix
166.806 Reputation
305 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
288 Mitglieder
821 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 20
Insgesamt: 1,447
