Zum Hauptinhalt wechseln
Lenovo ThinkPad Edge E530 HDD Replacement
Was du brauchst
Einführungsvideo
  1. Lenovo ThinkPad Edge E530 HDD Replacement, HDD Cover: Schritt 1, Bild 1 von 3 Lenovo ThinkPad Edge E530 HDD Replacement, HDD Cover: Schritt 1, Bild 2 von 3 Lenovo ThinkPad Edge E530 HDD Replacement, HDD Cover: Schritt 1, Bild 3 von 3
    • Switch-off the Laptop and remove the battery.
    • The HDD/Memory Cover is held by 3x Phillips screws. Remove them.
    • Remove the Cover.
  2. Lenovo ThinkPad Edge E530 HDD Replacement, HDD (Hard Disk Drive): Schritt 2, Bild 1 von 3 Lenovo ThinkPad Edge E530 HDD Replacement, HDD (Hard Disk Drive): Schritt 2, Bild 2 von 3 Lenovo ThinkPad Edge E530 HDD Replacement, HDD (Hard Disk Drive): Schritt 2, Bild 3 von 3
    • There are 2 x philips screws, securing the HDD Caddy Case. Remove them and slide the HDD to disconnect it from the SATA Connector.
    • The Caddy Case is held to the HDD by 4x Phillips screws. Remove them and separate the HDD from the case.
    • After installing the new HDD you must install a new OS or clone your old HDD.
    • You can install SATA HDD, 2.5" up to 1TB.
    • Did you do it successfully?
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
ZFix
191.368 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
321 Mitglieder
1.466 Anleitungen geschrieben
2 Kommentare
Since you mention cloning, it would be good to know how to clone one’s old drive. Would this also clone any errors on the oldrive and then put them on the new drive???
David Abineri - Antwort
Thanks for the guide. It also works for the ThinkPad Edge E531 model.
Célestin Taramarcaz - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 15
Letzte 30 Tage: 39
Insgesamt: 10,218
